Water spots from hell!!!
Old Aug 6, 2003 | 12:32 AM
I dream of S's Avatar
Default Water spots from hell!!!
Ok I give up!! I can not get the water spots off of my friends Supra. We have tried everything that I have ever seen mentioned. Clay bar, polishing compound, vinegar, any other suggestions?
Old Aug 6, 2003 | 08:21 AM
Anyone?!?
Old Aug 6, 2003 | 08:41 AM
jeffbrig's Avatar
rubbing alcohol, in small amounts seems to do it. But that will also strip wax off the car. Use at your own risk....
Old Aug 6, 2003 | 09:08 PM
wanabe's Avatar
some ideas here:
http://store.yahoo.com/classic-motoring/re...mpaindefco.html
Old Aug 6, 2003 | 10:50 PM
Originally posted by wanabe
some ideas here:
Thanks for the link. I have been thinking about getting a porter cable for a while. Now I may have to talk my friend into getting one. Thanks again
Old Aug 7, 2003 | 03:53 AM
forsaken's Avatar
Depends if the waterspots are under the clear coat. Yes, sometimes this happens. A friend had this problem with his s4, and he can't do anything about it.
Old Aug 9, 2003 | 08:10 AM
Homer2's Avatar
are you sure they are waterspots?
and abrasives you have tried, was it by hand or machine ?
Old Aug 9, 2003 | 10:00 AM
Well they showed up right after we had a little rain and then it was really hot for the rest of the day, so I am pretty sure they are water spots. My friend at work said that if the paint job on the car was crap then it may have damaged the clear coat. We used a polishing compound, but I put it on by hand.
Old Aug 9, 2003 | 08:56 PM
wanabe's Avatar
reminder that any polishing compound also removes any other protection that you have on the car (wax, synthetic, etc.)-
so, dont forget to rewax after polishing!
Old Aug 20, 2003 | 02:18 PM
94NSX's Avatar
I don't think you have waterspots on the car, per se.
Judging from your description of rain followed by heat, what I think you have is an etching of a waterspot on the clearcoat. That means the damage is set. Rubbing compound should take that out.
pleasework
Apr 28, 2004 05:50 PM
Pdog
Nov 1, 2002 05:10 PM
kki3o
Jul 2, 2002 01:37 PM
amongmany
May 8, 2002 07:00 PM
IS200
May 22, 2001 04:44 PM
