Help routing Ignition switch into toggle switches
Hello everyone. So long story short, my tumbler failed so now I’m using the key for the immobilizer and a flat head on the ignition switch to turn my s2k to the on position and then once that’s all done I’m finally cracking over the engine with the push to start button. I just deleted the steering wheel lock, but now I need help routing toggle switches to the ignition switch so I can just flip up switches instead of using a flat head to turn the switch over. How would I go about doing this? Also is it possible to re route the immobilizer into a more hidden area so it’s not so easy to steal in case someone breaks into my garage?
not quite the help I needed. But new tumbler requires new key. New keys requires programming. I don’t want 2 keys. 1 to unlock the car and the other to turn it on… I’d rather much add switches to turn everything on and place my key some place hidden to satisfy the immobilizer. Also my car isn’t heavily modified. So I felt switches suite my car better as well. But thank you
What year is your car? It'll probably cost a bit more but you can replace the ECU with a Kpro and run whatever key you want. Or you can take the lock barrel to your local lock smith and see about fixing it or replacing it.
hondalovr13
Nov 30, 2019 12:24 PM
B.C.
Jan 25, 2006 09:57 PM
