South Florida Owners from South Florida
Flywheel Question
Old Sep 5, 2005 | 06:45 PM
batikan's Avatar
Default Flywheel Question
I want to buy a flywheel for my car. What do you guys think about Fidanza?? or should I get Comptech?? I realized that Toda and Spoon are a lot more expensive. Are they worth it?? I also need a place to get my parts installed. Do you guys know any good place?? I live in Boca Raton. The parts I need to get installed are:
V-AFC II
Spoon Exhaust w/ Testpipe
Groung Wiring Kit
Springs
Slotted Rotors
Sturt Bar
A-Pillar with Oil Temp and Oil Pres.
The Flywheel and the ACT Clutch Kit
I need a place with Dyno...
Old Sep 7, 2005 | 10:41 AM
S2KSuzuka's Avatar
MTS auto can install everything. Personally, I would return the ground wiring kit, they don't do anything to boost performance
954-581-9649
No Dyno, but he can install everything. then you can get it tuned
Mitch
Old Sep 7, 2005 | 12:20 PM
rateds2k's Avatar
What he said ^^^
Old Sep 7, 2005 | 12:54 PM
arcadence's Avatar
I used MCA Motorsports. Ask for Mike. I would go with the Toda flywheel. The Fidanza flywheel is two parts with a lot of screws. He charged $400 for install on the ACT clutch and flywheel.
Mike @ MCA Motorsports
14114 SW 139TH CT
MIAMI, FL 33186
(305) 251-5095
Old Sep 7, 2005 | 01:03 PM
S2KSuzuka's Avatar
PS I have the act pressure plate with the Comptech flywheel and I love the set up
Mitch
Old Sep 8, 2005 | 06:43 PM
tachman's Avatar
I've had the Comptech flywheel for almost a year now and like it. Toda is lighter / more aggressive, but I haven't driven an S with one, so I can't vouch for the difference. Several ppl. on this board have the Toda, and recommend it.
Old Sep 9, 2005 | 01:38 AM
S2KSuzuka's Avatar
both the Toda and the Comptech are excelent. the weight of both wheels is almost the same, however the distribution of the weight is different, the toda has it's weight near the center and the comptech brings the weight out to the edges. The reason behind this is the toda cannot be re-surfaced. When you change the clutch you may need to change the flywheel. The comptech can be resurfaced. That's why I went that route. Both flywheels allow the car to spool up faster than stock.
Mitch
RoninS2k
Mar 9, 2012 03:53 PM
batikan
Oct 3, 2007 08:16 AM
attack666
Sep 20, 2007 09:52 PM
luegos2k
Dec 7, 2006 03:55 PM
SteveUCI
Aug 7, 2006 07:20 PM
