Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
Clutch master cylinder
Old 11-10-2002, 12:14 PM
Vin Diesel's Avatar
Default Clutch master cylinder
Hey guy's keep your eye on your clutch master cylinder mine is gone on a 2001 model only with 32,000 km. London Honda has order me a new one never seen this before fluid was black. Thank god for warranties...Vin
Old 11-22-2010, 04:52 PM
01s2k,kobie's Avatar
hey man i just discovered my clutch master cylinder has been leaking too and the fluid is black...wats the black fluid mean? and i didnt buy my s i trade a private owner for it do u think there is still a warranty? or wat do i need to do
Old 11-22-2010, 05:30 PM
o'malley_808's Avatar
LMFAO warranty? are you for real dude? This post is over 8 years old...
Old 11-22-2010, 06:03 PM
s2kcolin's Avatar
LOL... EPIC fail!!
Old 11-22-2010, 06:13 PM
shamusodoofus's Avatar
If this truly is a serious post, unless you somehow have extended warranty (which I doubt because you said you traded for it and seeing as you're unsure, even if the car did have extended warranty, you more than likely do not have the required paper work to make yourself eligible) the black fluid is generally dirt that gets into the master cylinder. From there when you push your clutch in and out it slowly starts to wear down the seals and eventually makes your master cylinder leak and thus useless. A new master cylinder will run you in the ball park of $150~ from your local Honda dealer. If your master cylinder is not leaking and your clutch fluid is black, I would highly recommend you change it ASAP before any more damage occurs. If you do decide to do the clutch (brake fluid) change yourself there is a DIY in the library section of the forum. You will require 1 bottle of OEM brake fluid. No that is not a typo, clutch fluid is the same thing as brake fluid.
Old 11-22-2010, 06:31 PM
afzan's Avatar
He's not even from Canada.. lol
Old 11-22-2010, 07:42 PM
Sgt.Mecca's Avatar
ok so lets get this straight...
Vin Diesel
Hometown: "Hollywood"
Posted in 2002
Fast and the Furious release date.....2001
Anybody see where im going with this?
Old 11-23-2010, 09:39 AM
okay i didint look at the post date till AFTER i posted it....and doofs....im not a complete moron i know that "clutch fluid" is brake fluid .:facepalm:.
Old 11-23-2010, 12:22 PM
FineTunedPerformance's Avatar
Apparently you don't know how to change it, otherwise it wouldn't be black.
Old 11-24-2010, 05:00 PM
like i said...i just got the car
Quick Reply: Clutch master cylinder
