Differential Fluid
Differential Fluid
Hey folks,
I went to part source today to get some oil for my next oil change that i am about to perform. While there i figured that i should change my differential fluid as well. I asked for Mobil 1 75W90 but they didn't have any but they did have castrol 75W90 which i was forced to buying as there was no other choice. What do you guys think??? I should i use this oil or return it and look around for Mobil 1 75W90??? Any input is appreciated.
Honda... use HONDA Diff Fluid.
Considering that majority of us do not "push" our vehicles (at least I know I dont ) every day for long periods at a time. Honda Diff Fluid should be sufficient enough because it is engineered specifically for everyday use (temperature and wear).
If you are deciding to go to a track and abuse the vehicle, I would suggest using MOTUL .
Just my two cents
hope that helps
Just my two cents
hope that helps
80W90 will have a slightly thicker viscosity. If you track I say it's ok. Honda recommends a straight 90W so if you're a little thinner on cold, I don't think you'll have any issues.
Both are fine
Both are fine
Originally Posted by myflys2k,May 5 2009, 06:10 PM
why dont you join the group diff fluid day this saturday... Amsoil FTW
I still see a question mark beside my name, but, I'll be there.
BTW Is this a rain or shine event?
Forecast for Saturday is rain, however, I don't put much faith into it as it is always a 50/50 chance of being correct.
CosmosMpower
03-11-2006 05:07 PM
