Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
Differential Fluid
Old 05-05-2009, 03:54 PM
03STOOK's Avatar
Default Differential Fluid
Hey folks,
I went to part source today to get some oil for my next oil change that i am about to perform. While there i figured that i should change my differential fluid as well. I asked for Mobil 1 75W90 but they didn't have any but they did have castrol 75W90 which i was forced to buying as there was no other choice. What do you guys think??? I should i use this oil or return it and look around for Mobil 1 75W90??? Any input is appreciated.
Old 05-05-2009, 05:12 PM
wing's Avatar
I used the Castrol, 3 - 4 years ago, diff still works!
Old 05-05-2009, 05:15 PM
starchland's Avatar
either or will work fine w/o problem
Old 05-05-2009, 05:23 PM
windingemotion's Avatar
Honda... use HONDA Diff Fluid.
Considering that majority of us do not "push" our vehicles (at least I know I dont ) every day for long periods at a time. Honda Diff Fluid should be sufficient enough because it is engineered specifically for everyday use (temperature and wear).
If you are deciding to go to a track and abuse the vehicle, I would suggest using MOTUL .
Just my two cents
hope that helps
Old 05-05-2009, 05:37 PM
starchland's Avatar
im using motul in my diff...can be hard to find, but its non shear and only the best for our sensitive diffs
Old 05-05-2009, 06:10 PM
myflys2k's Avatar
why dont you join the group diff fluid day this saturday... Amsoil FTW
Old 05-05-2009, 07:42 PM
03STOOK's Avatar
So do you guys recommend 75W90 differential fluid or the Honda 80W90 differential fluid. I have read alot of mixed reviews about this. What do you guys think???
Old 05-06-2009, 04:58 AM
iDomN8U's Avatar
80W90 will have a slightly thicker viscosity. If you track I say it's ok. Honda recommends a straight 90W so if you're a little thinner on cold, I don't think you'll have any issues.
Both are fine
Old 05-06-2009, 04:24 PM
kookiemonster's Avatar
I hope that you are reserving some of that Amsoil diff fluid for me myflys2k.
I still see a question mark beside my name, but, I'll be there.
BTW Is this a rain or shine event?
Forecast for Saturday is rain, however, I don't put much faith into it as it is always a 50/50 chance of being correct.
cgper
03-24-2016 11:11 AM
lukas2k
11-29-2007 05:29 PM
nutar
08-11-2006 11:22 AM
CosmosMpower
03-11-2006 05:07 PM
CosmosMpower
03-10-2006 03:12 PM
Quick Reply: Differential Fluid
