SakeBomb Garage | Custom FPSpört Ohlins DFV Group Buy
#31
SakeBomb Garage (07-06-2017)
#32
Thanks! We are excited to hear your thoughts on these vs the vanilla Ohlins kit!
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
#33
I installed the kit this weekend and so far am very happy. I was worried that the 11k springs might be too stiff for the street, but softening the struts (I'm experimenting around the 16-18 clicks range) gives a better ride over small bumps than stock. It's noticeable that the springs are firmer on bigger bumps, and the soft setting (really only rebound is being adjusted) is apparent. For cruising it's a good compromise, but for aggressive driving, you'd want to go firmer. I'll try them out on the track in about 2 weeks which will be the real test.
Two small things I learned about installing the kit:
1) It's better to remove the old shock/spring combo from both sides before you install the new ones. Otherwise, once you install the new shorter shock/spring on one side, you'll need to remove an ARB link in order to drop the lower control arm on the other side enough to get the shock over it and out. Or you could use a spring compressor if you have one.
2) Install the remote adjuster on the driver side before you install the shock. The fuel lines make it hard to get an allen wrench on the adjustor hat once the shock is installed.
My wife and I drove around downtown Denver and she didn't say anything about the ride being different. I'm sure if I asked her, she would have commented as it is different, but the fact that she didn't say anything, even after she saw me installing them earlier in the day, says that the changes are small. Like I said up top, I'm quite happy that the street characteristics of this kit are as reasonable as they are. Can't wait to try them out on the track.
__________________
#34
__________________
#35
I was going by the Ohlins' Owners Manual which says "The adjustor affects the rebound, and also, the compression damping to a smaller degree".
#36
ONE SPORT KIT LEFT from our last run of kits! First come first serve These sell out fast but we're limited to the amount of components we can source, so for now it's not an item that we can keep on the shelf for extended periods.
Our next batch is scheduled in 6-8 weeks.
Please ask if you've got any questions and again these do include our remote adjusters for your rear panels.
-SakeBomb Garage
-SakeBomb Garage
__________________
#37
The knob adjusts BOTH rebound and compression damping at one time. The only thing you are doing with dual adjustable is decoupling the two, and adjusting separately. We've seen a lot of customers struggle with adjusting a single knob correctly, let along a 32x32 matrix / 2D map. You really need data logging to get the most out of 2 way adjustable suspension. With good valving on a single adjustable, we can set a very nice rate change for rebound and compression but with one knob... most of the time straying from this setting only makes handling worse unless you REALLY know what you're doing.
__________________
#38
Just curious, those of you who purchased these Ohlins kits from SBG, did you actually receive the remote rear adjusters? I got in on a set from this thread: https://www.s2ki.com/forums/sponsor-...1178739/page2/ and never did receive them. Emailed back and forth with SBG a few times and still never received the remote adjusters.
#39
I understand you said you've reached out before, I'd like to figure out what happened. Do you have a tracking number or order number I can look up? Shoot us a PM or an email again. We'll get this sorted out.
-- Christian
__________________
#40
Packed and ready to ship!
__________________
SakeBomb Garage
16
12-21-2018 07:27 PM
SakeBomb Garage
06-19-2017 12:48 AM
