HELP!
i finanlly got my motor back together, but i cant get it to start. It just turns over and thats it. I made sure that everything was plugged in right. im sure the specs are right. its been 2 days and i cant figure it out.
Go back and check all of your sensor leads and ground connections. We missed one connection after an engine change, buried deep under the intake runner and the car wouldn't run above VTEC. Probably a temp sensor. Check fuses too, ECU / Ignition circuit fuses especially.
Good luck
Good luck
Good luck
Good luck
