Texas - Central Texas S2000 Owners Central Texas S2000 Owners
Swerving Accel/Deccel problems
Old Sep 23, 2010 | 10:57 PM
1point3_to_2point2's Avatar
Default Swerving Accel/Deccel problems
im having problem with my car and i cant figure out what it is
more noticeable at higher speeds
when i start driving and i step on gas the car kind of jerks to the right
when i let off the gas after moderate acceleration the car jerks back to left
so far ive checked
tires pressures
alignment
and brand new tires (all same age)
Old Sep 24, 2010 | 04:09 AM
Mr3plus1's Avatar
Have you checked to make sure you dont have a bad wheel bearing?
Old Sep 24, 2010 | 07:33 AM
How can I check that
Old Sep 24, 2010 | 08:06 AM
RavynX's Avatar
I know this sounds silly but Hisham had the same issue and that was because his tires were put on in the wrong spots. On one side he had 245's in the front and 225's in the rear. Not sure how you're set up but make sure the right wheels/tires are in the right spots.
Old Sep 24, 2010 | 10:24 AM
s2k_2fast4u's Avatar
i had this happen to me, check your tire pressure!
Old Sep 24, 2010 | 06:36 PM
JoeDirt1927's Avatar
I'd check for bad bushings in the rear also. Since it happens under torque, it narrows the problem to the rear. Could possibly be a problem with the differential.
Old Sep 25, 2010 | 06:09 AM
senor_flojo's Avatar
From: All up in your inner tubes. Whatcha gonna do sucka?
not sure if you have the same symptoms, but I ended up needing new rear axels
XJS2K
Jun 28, 2014 12:57 PM
1point3_to_2point2
Sep 26, 2010 02:43 PM
amkaluta
Feb 10, 2009 09:22 PM
xyster
Apr 6, 2007 03:17 PM
Jaydem
Jan 8, 2006 08:08 PM
