Texas - North Texas S2000 Owners North Texas S2000 Owners Club
North Texas Club
New Alignment
Old Jun 11, 2003 | 12:38 PM
CMiS2K's Avatar
Default New Alignment
Before
Front
Left Right
-.8 -.4 camber
5.7 6.2 caster
-.29 -.26 toe (is this why I had so much oversteer?)
Rear
left Right
-1.8 -1.5 camber
.46 .35 toe (or is this is why I had so much damn oversteer?)
__________________________________________________ _______
NOW
Front
Left Right
-1.3 -1.3 camber
6.4 6.4 caster
-.03 -.01 toe
Rear
Left Right
-2.0 -2.0 camber
.26 .21 toe
Guys tell me what you think?
Old Jun 11, 2003 | 01:30 PM
Gernby's Avatar
Former Sponsor
Your toe looks similar to what mine did. Lowering the car made the front toe out, and the rear toe in. Your rear toe in should have reduced oversteer, while the front toe out could have increased it. What is surprising is your front camber. I'm surprised your camber was so low. Mine was much more negative after lowering it.
Old Jun 11, 2003 | 01:40 PM
Gernby's Avatar
Former Sponsor
Here is what mine were after the JICs
Before (After the JICs)
Front..............Left..........Right
Camber..........-1.0.........-0.8
Caster............6.1..........6.1
Toe.................-0.125.......-0.125
Rear...............Left.........Right
Camber..........-2.3.........-2.1
Toe................0.22.........0.125
Thrust Angle..........0.09 deg.
After
Camber..........-1.0.........-1.0
Toe.................0.0.........0.0
Camber..........-1.2.........-1.3
Toe.................0.125........0.125
Thrust Angle..........-0.01 deg.
Old Jun 11, 2003 | 02:49 PM
CMiS2K's Avatar
they were able to get more caster than I thought they could,+6.4 caster with -1.3 of camber was pretty good.
Why are there so many maximum variances per car?
I went with more toe in the rear to keep the oversteer down. Nerces thinks that I should be able to really handle a corner with confidence now.
Old Jun 11, 2003 | 02:52 PM
cdelena's Avatar
Numbers look good. It should feel different with those changes.. what do you think so far?
Old Jun 11, 2003 | 03:03 PM
CMiS2K's Avatar
Well I was able to hold the 635W to 161S loop at 90 mph on street tires. 80 mph was about the max before.
I have been in the office all day and haven't been able to get back out. I will be hitting the streets tonight.
Do I need to re-check my ride height now or leave it alone?
Old Jun 11, 2003 | 03:40 PM
Gernby's Avatar
Former Sponsor
Leave your ride height alone. If you change it, you will need another alignment.
Old Jun 11, 2003 | 04:00 PM
CMiS2K's Avatar
ok
Old Jun 11, 2003 | 06:08 PM
Gregg Lee's Avatar
I assume the toe is in degrees and that minus toe means out. If so,
before: everything except front toe is within factory spec. The front toe out is enough to cause quick tire wear on the inside, but not enough to cause unusual handling. There is no one answer to what causes oversteer. It's a combination of tire size and brand and pressures, swaybars, spring rates and driver technique just to hit the big ones,
after:
Looks fine. You don't really want front toe out, but this is essentially zero. Stick with this and get the car balanced working on other things. Everything mentioned above has more impact than further minor alignment tweaks.
And checking track handling on the street is probably not useful (not to mention risky) For example the loop you mentioned likely slopes up or down and is banked as well. Both of these can significantly affect over/under steer. Also conditions vary day due to weather, dipped oil and antifreeze, etc.
And then there is the placebo effect.
Gregg
[QUOTE]Originally posted by CMiS2K
[B]Before
Front
Left
Kaneda215
Aug 11, 2011 09:16 AM
madness
Feb 14, 2011 03:50 PM
Hitman
21
Nov 29, 2005 01:40 PM
exceltoexcel
May 5, 2004 04:15 PM
exceltoexcel
May 5, 2004 09:29 AM
