3rd to 2nd when looking for 4th
Old Oct 26, 2012 | 06:57 AM
Ultra_Nexus's Avatar
Originally Posted by Si2k
I thought the AP2 retainers were only on 2.2 (heavier were ok on a lower reving engine)
Nope, they were from 2004 onwards on all engines.
Old Oct 26, 2012 | 06:58 AM
Originally Posted by Spies
Can't you pull the over-rev information from the ECU with Torque or similar?
No.
The only way you can tell if the engine has been damaged during an over rev is to check compression and inspect the retainers.
Old Oct 26, 2012 | 07:17 AM
zzkamikazezz's Avatar
Didnt the person on hear recently having problems with an S2000 he just bought have the dealer show him a log file showing an over rev though? Is this something only dealers can do?
Sure it won't tell you if anything is damaged but it can tell you what the revs actually went to?
Old Oct 26, 2012 | 07:20 AM
Montag's Avatar
Thanks for the feedback chaps. My mind is pretty much at rest now, just in time for the weekend.
I was surprised to miss that shift last night, seeing that I've been running with an ETD fitted for a few weeks now and I was expecting it to make the whole gear change smoother. Anyway, time will tell if I've buggered it up...
Old Oct 26, 2012 | 07:24 AM
The fact that the shift is soooo smooth is the reason you hit 2nd.
Usually, the synchros will make the selection of 2nd very difficult, but with the S2000 box being as slick as it is, combined with all the tweaks you have, it made it easy to do.
I genuniely think you'll be fine Dan.
Old Oct 26, 2012 | 07:35 AM
Montag's Avatar
I'll hold you to that, Ron!
Cheers for your help - I value your input.
Old Oct 26, 2012 | 09:53 AM
blue monster's Avatar
I did exactly this on mine not long after buying it 5.5 years ago and as per you did reacted quickly and got the clutch pedal pressed down immediately - to date I have had no issues
Old Oct 26, 2012 | 01:46 PM
richmc's Avatar
Did the same a couple of years ago, gave it a bad bounce before I realised what had happenened, so far so good.
s2kguy123
Jun 7, 2011 10:39 AM
Dumas2k
Sep 24, 2010 10:06 AM
Suzukuh
Sep 6, 2006 11:32 PM
shauniewalnuts
Jun 3, 2004 09:01 AM
blessed
Jan 31, 2004 03:04 PM
