ABS - Help please....
Old Apr 4, 2006 | 05:11 AM
Lloyd Six's Avatar
Default ABS - Help please....
My MY03 has got the ABS check light staying on, I know what the fault was, it was down to the front sensor was cracked. I have replaced that but the light remains on.
I have tried leaving the ABS fuse out for 20 mins.. no joy.
I have also tried disconnecting the battery for an hour, still no good
Any ideas how to reset the ABS and clear its codes or what equipment would do this??
Honda want silly money just to plug their kit in
Old Apr 4, 2006 | 05:24 AM
oxhouser's Avatar
You need a tool called a SCS short connector then follow the procedure
NOTE: This operation can also be done with the Honda PGM Tester.
1. Connect the SCS short connector to the service check connector (2P) located under the steering column.
2. Depress the brake pedal.
3. Turn the ignition switch ON (II) while keeping the brake pedal depressed.
4. After the ABS indicator goes off, release the brake pedal.
5. After the indicator comes on, depress the brake pedal again.
6. After the indicator goes off, release the brake pedal again.
7. After a few seconds, the ABS indicator blinks twice and the DTC is clear. If the indicator does not blink twice, repeat steps 1 through 6. If the indicator stays ON after the indicator blinks twice, check the DTC because a problem was detected during initial diagnosis before shifting to DTC clearing mode.
8. Turn the ignition switch OFF and remove the SCS short connector.
Conditions for DTC clearing
s Vehicle speed is 6 mph (10 km/h) or less.
s The SCS short connector is connected before the ignition switch is turned ON (II).
s The brake pedal is depressed before the ignition switch is turned ON (II).
Old Apr 4, 2006 | 06:09 AM
Lloyd Six's Avatar
so its normal that the ABS light will not go out even tho the faulty unit has been replaced??
hayabusa1285
Jul 3, 2011 06:41 PM
FUGITIVEX
May 26, 2010 09:46 AM
TatWongkungfu
Oct 20, 2009 12:07 AM
RobJ1
Apr 10, 2008 07:50 AM
