Aftermarket Stereo + Dash Controls?
My cd player only plays on the right hand speakers, dealer said it was the BUS cable and would need replacing. Said they could do it under warranty but would require ripping out both seats, carpets and trim, and they'd need it for a few days. If i did this i'd probably be taking it back with loose trim and squeaky seats from day 1, so i've opted for a replacement headunit.
I would like to keep the cockpit stereo controls still working, the only manufacturer i've found is alpine.
http://caraudiosecurity.com/catalog/produc...products_id+489
Is that the correct cable to use the exsisting stereo controls?
Any recommendations on a stero? I'd like mp3 playback and possibly a screen output for dvd.
Cheers
Cheers
I've got a Alpine CDM-7871RM (it came with the car) and it works with the dash controls except every now and again I'll use the volume controls and it will skip a track on the cd or change radio station instead, very helpful.
That doesn't happen very often and it appears to be a pretty good stereo. I've been thinking about getting an iPod sleave thing fitted but I haven't got round to getting it organised yet.
I have removed a factory installed 'bus' cable and it took me no longer than 15minutes.If you plan to replace the head unit the simplest solution is to get an Alpine head unit that is 'remote enabled' as this allows you to use the Alpine KCE dash control adapter.
Since I went for an MP3 head unit I rarely use the (MP3) CD changer.
If you don't want to be tied to Alpine (as they are currently the only head unit manufacturer currently providing a dash control interface), you could do as I have done and get an interface custom made for sub
Alpine isn't the only manufacturer to supply a control to radio interface, Clarion also do. If buy over a certain model (I cannot remember the cut off point, but I have the 948RMP which is fine), they provide harness that takes the input from the dash and puts into a port on the back of a the radio.
Part number for my radio for the S2000 is RCE-106W, costs
Stratocaster
Jun 5, 2003 06:38 PM
