Alignment + bolts
Old Jul 6, 2006 | 11:53 PM
Si2k's Avatar
Default Alignment + bolts
I'm going to be getting my car aligned later to the original Honda settings. Shouldn't be too much of a problem unless of course, from reading other posts, the bolts are seized.
The car is 6.5 yrs old and has 91k on the clock. It's very likely that the bolts would be seized I would think. I will tell them to only adjust the settings if they can loosen the bolts. I dont want them snapping a bolt and then leaving me car less whilst I wait for parts from Honda.
What bolts are likely to sieze and hence not allow parts of the alignment to be done? I am hoping the track control arms are not prone to seizing.
Thanks in advance guys.
Old Jul 7, 2006 | 12:03 AM
Bassoctopus's Avatar
All the info you need is in the tech faq.
Old Jul 7, 2006 | 12:08 AM
eSeM's Avatar
I doubt they would be able to snap any of the bolts off ....... took me a couple of hours to saw through one with a hack saw.
Yes! the control arms are prone to seizing.
Are you aware of the costs involved with fixinf seizure problems?
Old Jul 7, 2006 | 12:14 AM
Si2k's Avatar
Yeah, very expensive
If they are seized then its the cost of the parts that scare me the most. As mentioned in some posts, hopefully they will be able to loosen them just enough to allow them to adjust settings. I guess the fact the car has been driven lots reduces the chance of seizing as the suspension is always moving rather than sat still for weeks.
Old Jul 7, 2006 | 01:07 AM
Si2k's Avatar
Are the toe control bolts on the rear prone to seizing?
Old Jul 7, 2006 | 01:09 AM
eSeM's Avatar
Yes!
Old Jul 7, 2006 | 01:11 AM
Si2k's Avatar
Originally Posted by StevenM,Jul 7 2006, 01:09 AM
Yes!
Ok, thats the main think I want to get adjusted really, the tracking front and rear.
Odd that they don't use a threaded toe control arm similar to track rod ends on the rear.
Old Jul 7, 2006 | 09:51 AM
Si2k's Avatar
Sorted. Much better now after just getting the tracking done, rear was a fair way out. Just need to do the camber now but I can do that myself.
Felt really good on way home, think I need to get rid of the A pillar though as it's blocking my view
Old Jul 7, 2006 | 12:16 PM
MB's Avatar
MB
Member
Get yourself a can a Plus Gas and douse the bastards big time!
It really helps
Edit: just realised you've had it sorted
MB
Old Jul 8, 2006 | 03:27 AM
mikey k's Avatar
I'd have extracted the bolts and greased them before doing the alignment The worst ones are the front caster as they are vertical allowing water to just sit on the top of the bolt
Weird thing is looking at high mileage cars that are used regularly the bushes don'r seem to sieze, probably because the corrosion doesnt get a chance to build up.
BTW the upper wishbones bolts are prone as well, since Honda decised to put a spline effect on htem
robrob
Sep 29, 2015 05:43 PM
jonmizu
Feb 9, 2012 08:11 AM
loftust
Nov 23, 2008 12:45 PM
wingnutLP
Sep 6, 2007 11:02 AM
Rhino80
Mar 3, 2006 03:49 AM
