Another CEL topic
Old Mar 24, 2011 | 01:02 PM
trongo88's Avatar
Default Another CEL topic
Hi guys, had a topic about my CEL light giving the code P0420, as I have a Decat in it's kinda common! The CEL
Normally comes on when am Doing 60mph
But tonight when on the motorway, the light switched itself off! After a bit of hard driving light hasn't come back! I booked my car in to get a sport cat fitted next Tuesday!
CEL hasn't come back, but anyone experience this before? Cheers
Old Mar 24, 2011 | 01:10 PM
MB's Avatar
MB
Member
CEL can go away if the fault comes back into parameters within a given time. In your case you must have has a sustained blip in emissions from the secondary sensor, which has gone away. Normally a few miles of normal readings will make it go away.
I would just fit a lambda spacer rather than a sports cat. They are still quite restrictive.
Old Mar 24, 2011 | 11:56 PM
Jayboy83's Avatar
I have a garage R decat on my car with the built in cel fix, but has also thrown the cel light. Is it advisable to add on another cel fix spacer to try and fool the sensor? And where would i get one from??
had it checked by honda and it is the decat thats put the light on, i have also thought about getting a hifgh flow cat, but dont really want to.
Old Mar 25, 2011 | 01:16 AM
MB's Avatar
MB
Member
Ring Garage R and tell them it doesn't work
Old Mar 25, 2011 | 02:37 AM
Jayboy83's Avatar
Could do, although i bought it off somebody else on here.
And after reading into it a bit more, found out that the later drive by wire models like mine usually still activate the light
Old Mar 25, 2011 | 02:40 AM
MB's Avatar
MB
Member
Stick some washers on it.
Old Mar 25, 2011 | 02:52 AM
Jayboy83's Avatar
good plan, i'll give it a go
2004TurboS
Sep 3, 2015 09:57 AM
s2kdriver80
Dec 8, 2011 10:28 PM
svencarlson07
May 10, 2011 05:11 AM
darkfx
Dec 27, 2005 08:08 PM
folex187
Nov 11, 2005 02:35 AM
