Battery cut-out switch?
Old May 21, 2012 | 01:30 PM
Hockenheim's Avatar
Default Battery cut-out switch?
OK, my battery I bought in late 2010 has had it as it has become sulphated after only about less than 3000 miles of use...... I was a little complacent and had it hooked up for too long over the winter and "spring" (more like bloody winter this year....). The only reason it was hooked up was that I was lazy and didn't disconnect the battery and have it recharged on trickle charger. I would like to buy a cut-out switch to isolate the battery - does any one of you use one and if so which one are you using?
Cheers.
Old May 21, 2012 | 02:01 PM
MB's Avatar
MB
Member
Autoelec one from Demon Tweeks.
You might not want to cut a hole in your dash though
Old May 21, 2012 | 02:07 PM
Hockenheim's Avatar
You are damn right I don't Nice cage
Old May 21, 2012 | 02:17 PM
richmc's Avatar
Cheers.
You are better off buying a battery conditioner/charger, look at the C-TEK ones.
Old May 22, 2012 | 05:03 AM
Floppy's Avatar
I really don't know why Tom hasn't put his kill switches here instead of on the front wing?
Old May 22, 2012 | 02:23 PM
TommyS2000's Avatar
You need one inside and outside in the MSA regs mate.
Old May 22, 2012 | 02:36 PM
Hockenheim's Avatar
Originally Posted by richmc
Cheers.
I've got a reasonably good one though not CTEK. Serves me right I guess for neglecting the battery..... It would have discharged much less had I just disconnected the battery but didn't know that late April the council were still throwing salt on the road so car just stayed in the garage. With the cut-out switch it will just be a turn of the dial/knob to disconnect the battery.
Old May 22, 2012 | 02:44 PM
keith2.2's Avatar
Originally Posted by richmc' timestamp='1337638627' post='21718037
[quote name='Hockenheim' timestamp='1337635859' post='21717896']
Cheers.
[/quote]
given that you only need to do it when not using the car for long periods, is a lot off faff for the sake of avoiding popping the bonnet and pulling off the +e terminal
ralper
Jan 18, 2017 07:47 AM
I-vtec. Do you?
Dec 11, 2016 12:46 PM
Legal Bill
Dec 18, 2014 06:27 PM
User 121724
Dec 21, 2007 03:38 PM
darkwatch
Nov 19, 2007 08:00 AM
