Best place to get a HEADLIGHT washer pump other than Honda
As far as I'm aware, you don't need it for the MOT. I got annoyed with it dribbling up the bonnet when I washed the windscreen, so removed the fuse. Passed the MOT in that state a fortnight ago!
From what I understand from March, 2013 onwards if you've got headlight washers they must work & are part of the MOT hence me needing to get this sorted.
Rich, been on eBay & as mentioned above breakers are looking for £40 for a 2002-2003 unit which I'm not prepared to pay as I could be in the same position again in 3 months time
Sent from my SGS4
Sent from my SGS4
Could you remove the guts of the oe pump and then fit a readily available pump in line after the oe to supply the washers?
Sent from my SGS4
Sent from my SGS4
It seems my windscreen jets have stopped working and I hear nothing at all when I pull the arm to spray it...Need to check if its a fuse or whether its the pump itself. Good to know halfords do them for a fiver!
Has anyone got a part number for the halfords windscreen washer pump or has anyone tried this one out off fleabay?
fleabay washer pump
fleabay washer pump
Kris-S2k
01-16-2012 02:20 AM
