Bizarre Weight Saving Suggestions
Old Jul 26, 2002 | 04:19 AM
Polemicist's Avatar
Default Bizarre Weight Saving Suggestions
There seems a lot of wild 'n' wonderful suggestions for getting the weight down and the power-to-weight ratio up of the S2000, so there's gotta be a fun thread here!
I'll start it off with one for the guys:
Circumcision - should save a few grammes...
Old Jul 26, 2002 | 04:24 AM
Tifosi Red's Avatar
you've already posted my first choice - a really big 'elimination' as the US guys coyly name it
Remove those heavy clunky alloys and run a set of 2CV rims with OEM 115mm rubber - less aero drag and rolling resistance too!
Old Jul 26, 2002 | 04:28 AM
Frenchie's Avatar
Remove all Tif's ICE and scrub off all the polish
a saving of at least 42 kilos
Lurking Lawyer's Avatar
Appendectomy? Tonsilectomy?
Driving in the buff....?!
Polemicist's Avatar
... and what about under arm shaving for the chaps to remove that weighty hair
Old Jul 26, 2002 | 04:35 AM
Frenchie's Avatar
I just saw Tif's post in another thread about the weight of ICE in someone else's boot
You know I'm only joking, though, don't you Chris I'm just jealous really
Old Jul 26, 2002 | 04:42 AM
Tifosi Red's Avatar
lol but at least I'm not spending $100's at the same time on Ti exhausts to 'save weight' Pete!!
Here is the thread that really cracks me up my hood prop is too heavy
Old Jul 26, 2002 | 04:48 AM
W6DAN's Avatar
Cut your fingernails and toenails ... and those of your passenger.
Blow your noses, go to the toilet. Take any change/sweets/tissues out of your pockets.
Remove the airbox cover, don't keep the oil topped up.
Take out any CDs you don't often play.
Remove toolkit and padding from the boot.
Discard all caps, including oil and petrol.
Old Jul 26, 2002 | 04:55 AM
ianl's Avatar
I remember in the early '90's Nigel Mansell shaved off his moustach, when quizzed on the reason why, he cited weight saving/increased aero efficiency as the prime reasons
Old Jul 26, 2002 | 05:18 AM
Frenchie's Avatar
Just read it
OK. back on topic, here's my bizarre weight saving tips.....
Blow your nose (but remember to discard the tissue outside the car, otherwise you just transfer the weight elsewhere)
Replace the headlamp glass with clingfilm
Use WD-40 as your engine oil (on the basis that thinner = lighter)
Replace the seat belt with fishing line
Wipe your feet before getting into the car (or better still, don't wear shoes... but still wipe your feet)
Spit out of the window as often as you can
Pete
