Bourbon's S6000
Old Dec 12, 2013 | 04:24 PM
  #171
B0ZWELL's Avatar
need a hump like this?
i just happen to have a mould kicking around
Old Dec 12, 2013 | 10:15 PM
  #172
Krisbuc's Avatar
Quality so how you finding the swap so far ?
Old Dec 12, 2013 | 11:34 PM
  #173
Carl Bourbon's Avatar
I'm after something a little smoother more central and sort of in the shape of a tear, there's a car group called ukv8 and one of the guys knows a panel beater who will put in the bulge I need, kinda like the style of an BMW M5.
Hopefully.
Old Dec 12, 2013 | 11:35 PM
  #174
Enjoying it! Still doesn't feel real though.
Old Dec 13, 2013 | 03:25 AM
  #175
chrispayze's Avatar
Did your movable engine mounts work nicely?
Sent from my GT-P7310 using Tapatalk
Old Dec 13, 2013 | 03:56 AM
  #176
I put the the ease of fitting down to both mine and my friends abilities and the sliding mounts yes
It would have been a pig of a job otherwise!
Old Dec 13, 2013 | 04:04 AM
  #177
unclefester's Avatar
That also means you can line the engine and box up if they don't quite sit straight - i would imagine it's a good idea to have them in a straight line with the prop and diff?
Old Dec 13, 2013 | 06:15 AM
  #178
Straight indeed,
I've reused the honda gearbox mount with some relocating brackets which moves it 50mm back and keeps it central, the motor plate mounts are drilled in such a way to allow 5mm movement side ways.
The sliding parts were for the ease of how far forwards or backwards it needs to be
Old Dec 13, 2013 | 06:44 AM
  #179
WinFreak's Avatar
Seems easy enough
Could you just space the bonnet hinges for the moment to make it fit?
Old Dec 13, 2013 | 06:48 AM
  #180
Nick Graves's Avatar
Probably the wrong end and it'd be 4" up the windscreen.
Congratulations - now comes the difficult part(s)...
