Bourbon's S6000
I've solved a problem today that I thought would be a right bugger.
As you probably know the S2 has electric power steering, the Ls engines have a power steering pump on them.
This means that the auxiliary belt would need to be shortened when this pump is removed or a jockey wheel and bracket made to emulate the power steering pulley.
Today I came up with the idea of gutting out the internals of the pump, plugging it up and using the pump itself as a jockey wheel. This way it retains stock location and the stock charger belt can be used also!
On top of that there's no Frankenstein bracketry and pulley on display!
Also still requesting the musings of a fuel line/fitting expert. Cheers!
Machined the back of the steering pump mount, taken 6mm off the back which is the thickness of the engine mount plate, that way the pulley will still line up with the aux belt.
The motor plate mounts over where the steering pump used to, so now it has to sit in front of the plate, moving it forward 6mm, hence machining the mount thinner
Quiz time!
What's new?
Here's another just because
And another
So yeah this weekend has been a busy and draining one. Got through a lot on the niggles list and a couple of other bits, still some to do which I hope to sort out tomorrow before I do two night shifts.
I'll run through the updates tomorrow night whilst I'm at work
But for now feel free to try and guess!!
