camera mount
Old Sep 29, 2008 | 01:49 PM
streffie's Avatar
Default camera mount
i recently saw a camera mount on here where the owner had mounted it under the wind deflector and it sat forward othe the deflector and was very decrete can any one tell me who it is ?
Old Sep 29, 2008 | 01:57 PM
eho's Avatar
eho
try the link below..
http://www.modifry.com/products/moun...windscreen.htm
Old Sep 29, 2008 | 01:59 PM
MB's Avatar
MB
Member
Is it for a bullet cam or camcorder?
Old Sep 30, 2008 | 12:15 AM
GavB's Avatar
Pretty sure the one you refer to is the Modifry one. I have one, it looks like this:
As MB says, you need to decide what you are going to mount on it. The wind deflector mounts on the lid of the centre console and so it is not solid, put too much weight on there and it will vibrate and make your vids look crap.
The camera mounted on it in the photo above would be too big for example. A bullet cam or at the most a small IXUS style compact work fine. I do mount my camcorder on there but have had to improvise all sorts of lashings and stifners to get acceptable results.
Hope that helps.
Old Sep 30, 2008 | 12:57 AM
nomadicS2k's Avatar
You get a decent amount of wind noise with those kind of mounts. If you can spend a little more cash and get the mounts for the windscreen that would be loads better! And then you really do get a good picture with decent sound quality.
Old Sep 30, 2008 | 12:58 AM
muttly's Avatar
if you want a rally good one look at my post of earlier in the year, the mount fits to the window, the same company also produces other mounts. A klot of there equipment is used by the BBC so it must be preety good
https://www.s2ki.com/forums/index.php?showtopic=572783
Old Sep 30, 2008 | 01:17 AM
lovegroova's Avatar
I use a Quad sucker windscreen mount which I got from fastfilms. Works a treat
https://sslrelay.com/www.fastfilmsshop.co.u...%3D28FFQSW%3D29
Here are some vids taken with it using a camcorder.
On track http://www.youtube.com/watch?v=BQVN0Kge3lI
On road http://www.youtube.com/watch?v=kogV6u3_6ko
It easy to put on and take off, and is very stable. Works a treat.
Old Sep 30, 2008 | 01:28 AM
eSeM's Avatar
Camera mounts located on the wind deflector location are not very good for shooting forward but are good for taking shots behind ...... unless you have a Mugen wing installed
It also helps if you have a camera/video that has image stabilisation.
Old Sep 30, 2008 | 02:51 AM
Ultra_Nexus's Avatar
If you have an early model S (with the mesh helmet holes) and a compact camera, you can cable tie your camera to the seat. Gives a good video too!
I'll post one up in a min once it's uploaded
EDIT - working now
http://uk.youtube.com/watch?v=SwWMvZImLPk
papdoc
Αγοραπωλησίες
Feb 17, 2013 01:30 AM
Justin Yoo
Socal Swap Meet
Dec 10, 2012 10:10 PM
freq
Apr 6, 2006 05:31 PM
revhi
Jun 13, 2005 11:30 AM
tritium_pie
Jul 1, 2003 04:27 PM
