CEL is on
Old Jan 10, 2008 | 01:25 PM
  #81
Dembo's Avatar
[QUOTE=Shipley,Jan 10 2008, 10:09 PM]I was under the impression you only needed one to do both jobs.
Once the pulses are effectively slowed (no longer KPH but MPH) then in theory the speed limiter wouldn't kick in until a speed higher than the car can go
Make any sense ?
Old Jan 11, 2008 | 04:30 AM
  #82
MC_BLADE's Avatar
[QUOTE=Dembo,Jan 10 2008, 10:25 PM] Yes, but it's a problem of where the wire is split. It splits once, with one going into the ECU. Then another wire disappears off behind the dash where it splits in two again with one going to the speedo, and one going to the EPS.
If you want the EPS to get the correct unmodified speed, you need two converters: one after the first split and before the ECU, and one after the second split before the speedo. Attempt at a diagram:
[CODE]
gearbox ------------------------------------------------------------------------ EPS
Old Jan 11, 2008 | 09:20 AM
  #83
GrittyShaker's Avatar
Right, I'm going to stick with the way it was originally done. Stop putting ideas in my head.
One more quick question. I know the connection won't be as good as a soldered one but, is there a particular reason why I can't just crimp on some butt connectors and use heat shrink insulation to protect the connection?
Old Jan 11, 2008 | 12:05 PM
  #84
MC_BLADE's Avatar
water ingress and corosion over time wont make for a good conection, hense the term dry joint. Personaly with it being under the car get the iron out do it right once never have to do it again. The extra 5 mins now may save you doing this exersice again.
And to your idea of using shrinkwrap. Tidy and precise means you wont have to keep repairing
Old Jan 11, 2008 | 02:53 PM
  #85
Excellent. I'll be doing that in the morning(ish). Only just got in, and I fancy a sleep in.
Old Jan 11, 2008 | 05:50 PM
  #86
MC_BLADE's Avatar
Just couldn't get do it once and well, too much in that post could I. Blumming painkillers messing up my thought process, Cant wait for my leg to heal so i can get back out in the S
Old Jan 12, 2008 | 05:37 AM
  #87
'Nuff said.
Old Jan 12, 2008 | 07:12 AM
  #88
s2konroids's Avatar
Originally Posted by GrittyShaker,Jan 12 2008, 02:37 PM
'Nuff said.
Nice one scott!
Old Jan 12, 2008 | 07:37 AM
  #89
Originally Posted by Ajs_s2k,Jan 12 2008, 04:12 PM
Nice one scott!
Thanks for everyones help.
My God, it's weird to have power steering again.
Old Jan 12, 2008 | 08:34 AM
  #90
MC_BLADE's Avatar
Glad its sorted mate Now we need to get you in someone else
