changed cat
Old Sep 14, 2008 | 09:24 AM
  #21
nashby's Avatar
do you think that small amount high would cause that, i know i have complained about my car in the past but i really am getting so fed up with it,
Old Sep 14, 2008 | 09:28 AM
  #22
Si2k's Avatar
Ive had my cat on and off a few times. Throttle is definately crisper with the cat off.
Old Sep 14, 2008 | 09:30 AM
  #23
Si2k's Avatar
Ive had this a few times, i can only think that oil in getting into the breating system during spirited driving (twisty B road)
  #24
martin j's Avatar
Too much oil is bad, even if i's only a little, the blue smoke should stop once it's down to the mark, just keep an eye on it.
Old Sep 14, 2008 | 09:32 AM
  #25
nashby's Avatar
You know what there are times when i love this car and really enjoy it but its such a pain in the arse some times
Old Sep 14, 2008 | 09:34 AM
  #26
nashby's Avatar
Yes i will, i check it very often, and its the same colour it was when it went in i just dont want to damage it. Its only a minute amount over
Old Sep 14, 2008 | 09:36 AM
  #27
nashby's Avatar
also should i have reset the ecu after fitting decat pipe?
  #28
MB's Avatar
MB
Member
When cold?
ECU reset is unrelated to your issue, and it's not really needed.
  #29
nashby's Avatar
yes when cold, level ground
Old Sep 14, 2008 | 10:41 AM
  #30
FunBox's Avatar
Maybe the heat that would othewise be absorbed and disipated by the cat is burning oil from the remaining pipe?
