Code readers
Old Nov 24, 2009 | 07:06 AM
MB's Avatar
MB
Member
I'd probably only advise using data gathering / diagnosis is the car is heavily modified, otherwise you probably won't be looking at much interesting.
I've seen people get tangled up in looking for problems which aren't there, due to a minute difference from one reading from one day to the next. Plus the car is pretty reliable and faults are quite rare.
They are useful when you do a fault though - and really all you want to see is the voltages from the main sensors.
If you want to play with graphs and things then i'd suggest something laptop based. Never used any so can't give any advice there (i've never needed more than a fluke on a modern car)
There are some good books out there too - there was a Haynes one on engine management from memory.
Old Nov 24, 2009 | 07:36 AM
OldDogmeat's Avatar
I'll likely just stick with your initial advice then I think..
Cheers
Old Nov 24, 2009 | 07:57 AM
s2konroids's Avatar
for me I was interested in coolant, ign timing, fuel trims, map etc bit that's because the car is modified.
garyo
Feb 27, 2012 10:35 AM
Nottm_S2
Jul 4, 2011 08:12 AM
robdownes
May 15, 2007 02:00 PM
Rawhide
Apr 18, 2006 06:15 AM
oatnet
Dec 8, 2005 08:45 AM
