Corrosion
Old Jul 10, 2008 | 03:42 AM
CHIPPO's Avatar
Default Corrosion
Just had the wing liner out of the offisde wing to sort out a problem with the windsreen washer pump( Brushes worn out new unit required ) But did notice a lot of minor corrosion beginging to occur esp where bottom edge of wing is welded to chassis. Previously noted some monor corrions between parts of main chassis mebers that are spot welded together in engine bay and have contiually treaed with waxoly and so far kept in check. Also noticed a lot of corrsion when up on ramps for tyres etc in odd spots and esp sub frames etc. Car is 51 plate owned since new 52k on clock never crashed or even minor repairs, needs respray due to serious stone chip situation, any comment????????
Old Jul 10, 2008 | 03:50 AM
jakesalter's Avatar
Is car put away in a garage whilst wet? Do you drive it through the winter? Are the roads near you particulary gritty? Do you regularly clean the underside of the car with pressure washer? Endless questions and contributing factors..
Old Jul 10, 2008 | 04:17 AM
euan's Avatar
Not unusual I would say - my 02 was showing signs of that before I PX'd it for an 05.
Old Jul 10, 2008 | 05:10 AM
CHIPPO's Avatar
First 3 years kept in open
laterly in dry wel lventilated car port with cover ( to keep the bloody cats of
Essex roads
shiv
Jul 30, 2017 07:03 AM
frenchy
Mar 11, 2016 09:26 AM
rainbow_s2000
Dec 14, 2015 02:42 PM
boyguan
Jan 12, 2014 10:31 PM
EastLondonS2K
May 23, 2011 03:45 AM
