CV cups
CV cups
I deceived to swap my CV cups around today but I cant work out how to re use the old cv clips.
Do you need a special tool or something or am I missing the obvious!
Can someone put me right.
Thanks
Thanks
Thanks leef and chippo that worked a treat but ive got one more question.....I noticed when I had bolted everything back in place I still had slight movement on both drive shafts coming from the diff end. Can you tell me if this is normal to have a small amount of play at that end or have I got more problems brewing?
Thanks again
Thanks again
Hope that makes sense.
Graham
And the answer is , if your get hold of the cups there is a touch of movement , never noticed really before so i must have presumed it was normal. I did have a feel for back lash of which there is very little.
Cheers
Graham
