Dash Rattle!!!! HELP!!
Old Feb 11, 2004 | 06:00 AM
iDLe*'s Avatar
Banned
Ok day 3 of ownership and loving the car but I'm still at the stage where I have to drive without any stereo as the engine sounds better than all of my CD's....sure this will wear off at some point, maybe?
But anyway this leads to me to the problem - a nasty rattle which stays around until I drop off to all but 5MPH. it sounds to me like its coming from the windscreen heater vents up on top of the dash, really annoying!! Sounds almost like an electrical fault kind of noise but I know it just something stuck in there as it only happens with vibration.
Can anyone help at all??
Cheers
iDLe*
Old Feb 11, 2004 | 06:05 AM
heffergm's Avatar
I had a monstrously annoying rattle that I was convinced was coming from the front passenger side dash.
However, it turned out to be the hood. You might want to adjust the rubber bump stops to make sure your hood is nice and snug.
Old Feb 11, 2004 | 06:09 AM
iDLe*'s Avatar
Banned
Ok - I'll take a look at the roof see if I can see anything but I'm almost 100% sure this noise is coming from the front screen heater grill, about centre dash.
Something fallen in there?
Old Feb 11, 2004 | 06:32 AM
Amuse Boy's Avatar
Sounds like it could be the rear view mirror. At the bas of the mirror where it attaches to the windscreen, there is a screw - tighten it. Worth a try.
Old Feb 11, 2004 | 06:43 AM
AquilaEagle's Avatar
Administrator
or check the passenger seatbelt. plug it into the sockrt and see if that's it... the cabin is so small that to determine where rattles are coming from can be very difficult
Busamav's Avatar
iDLe , It sounds just as if you were describing the one i have on mine. It is def coming from that area , i am going to risk asking the dealer to investigate it when mine goes back for other items in a weeks time .
itmt i will check the mirror base .
Old Feb 11, 2004 | 06:54 AM
AdrianEagle's Avatar
I found that I was getting a funny noise from the passenger seat area. It was not there all the time and after much agonising and cursing about the problem I finally discovered it was the misses!
Old Feb 11, 2004 | 07:14 AM
Amuse Boy's Avatar
Another thing you can check... open both doors and you'll see a hole in the side of the dash - remove the small cap and tighten the bolt.
Old Feb 11, 2004 | 07:30 AM
LLOYDJ's Avatar
[QUOTE]Originally posted by AdrianEagle
Old Feb 11, 2004 | 08:30 AM
M8TT J's Avatar
I have got a little rattle coming from the roof....only on bumpy stuff...does my head in and needless to say disappears when the roof is off.
Any suggestions....is it worth tightening up the hood bolts
Soladay.John
Mar 4, 2011 08:20 PM
VilleS2K
May 12, 2006 09:25 AM
MagicDave
Mar 16, 2004 11:26 PM
F2000
May 23, 2003 06:37 AM
HI REVS
Aug 12, 2002 02:40 PM
