Drivers side window
Old Apr 10, 2006 | 02:45 AM
dlofneps2k's Avatar
Default Drivers side window
My drivers side window make a horrible loud scratching noise when I lower it, on the way back up it is silent. The noise can only be described as rubbing chalk on a blackboard or metal on a ceramic tile, really high pitched.
Doesn't look like there are any scratches on the window itself, so I guess it must come from within the door.
Could this be down to the window coming loose in its holder? Is it easy to take the door cards off and check this myself?
Old Apr 10, 2006 | 02:55 AM
aldfort's Avatar
Yes it could and Yes it is fairly easy. There is some stuff about this problem in the Technical section on the main board.
Old Apr 10, 2006 | 02:56 AM
Middlers's Avatar
Try spraying silicone spray down there when the window is down.
Old Apr 10, 2006 | 05:56 AM
dlofneps2k's Avatar
This evening I shall attempt to remove the door cards and have a look inside, maybe a bit of grease on some of the moving parts will do the job
Old Apr 11, 2006 | 02:44 AM
AdrianEagle's Avatar
Or release the mouse!
2SoonS2K
Dec 21, 2012 10:59 AM
gambit-irl
Feb 19, 2012 09:41 AM
turbosix
Nov 20, 2011 12:46 PM
damn_son_s2k
Aug 18, 2010 01:32 PM
VTEC4-2
May 12, 2004 02:54 PM
