Engine Check Light (ECL) problem Code not listed?
Originally Posted by Spamsteiger09' timestamp='1329928322' post='21439220
He advised something to do with high voltage as a result of moisture in the system, just wondering if this is a result of dodgy waterered down petrol? Not sure when i filled up a week or so ago if the fuel cap was 100% tight, although seems like im looking for explanations.
You could try filling the tank with super and crossing your fingers. Check the connector if you can get at it. Otherwise, it's most likely to need a new primary lambda sensor.
-Brian.
You cant really clean o2 sensors IMO.
Search for 'walker' branded ones on here, lot of people have had success including me and are circa £75. Not that difficult really once you get it jacked up on axle just a bit of fiddling about underneath in tight gaps.
Just ordered another one( second ) for mine ( Pre cat sensor ) as it threw the same code a while back. I cleared the code and it hasn't returned but it's quite clear it's running a little rich so something is definitely not right.
They seem to last a couple of years or so with a lot of short runs.
Thanks for that, will search for a walker one, I assume it's down the front end of the car on the manifold ?
