Engine Damper
Old Apr 14, 2009 | 02:39 PM
Ultra_Nexus's Avatar
Default Engine Damper
Well I fitted the engine damper the other day in a bid to preserve the engine mount I repaired.
What a huge difference it makes!
Without, the engine has a lateral movement of a good 2-3" at the top.
With, the engine only moves maybe 0.5" MAX so a huge improvement.
Throttle response is GENUINELY improved too.
What a top mod.
Old Apr 14, 2009 | 02:49 PM
m1bjr's Avatar
I could use one for down the pub - looks good!
Old Apr 14, 2009 | 02:58 PM
DAT International's Avatar
That looks great. Where can i get one? lol
Old Apr 14, 2009 | 03:30 PM
Oh BTW Steve - finally ordered a grounding loop filter for my audio!
Hopefully do the trick!
DAT - http://shop.ebay.co.uk/?_from=R40&_trksid=...-All-Categories
You are looking at
Old Apr 14, 2009 | 11:11 PM
s2konroids's Avatar
Looking good Ron, i have the NRG one fitted.
I found it made a difference but not massively.
I found a more direct feel when putting my foot down and shifting/better gear shifts
I maybe have not tightened it enough.
Old Apr 14, 2009 | 11:25 PM
baldy2007's Avatar
look es good
Old Apr 14, 2009 | 11:28 PM
jonner's Avatar
Nice job....
Old Apr 14, 2009 | 11:46 PM
Pie_n_Chips's Avatar
What a top mod.
Under bonnet bling, nothing more.
Your noticing a HUGE improvement because your mounts are shagged, allowing the huge amount of play your experiencing.
I'd consede throttle response may have improved due to you engine no longer being able to swing around as much in the bay, but come on
Old Apr 15, 2009 | 12:05 AM
willf's Avatar
Agreed - its because your mounts are munched!
Old Apr 15, 2009 | 12:55 AM
98RON's Avatar
It looks trick for sure!
But if so good/necessary, then why wouldn't Honda would fit one as standard?? They didn't exactly skimp elsewhere on the S engine-wise.
Good work though
