Engine Damper
Originally Posted by 98RON,Apr 15 2009, 09:55 AM
It looks trick for sure!
But if so good/necessary, then why wouldn't Honda would fit one as standard?? They didn't exactly skimp elsewhere on the S engine-wise.
Good work though
Good work though
Cost & target audience
Fitting the damper allows more vibration into the cockpit potentially pi55ing off a lot of customers.
Sure, they could have weened the vibes out, but that would cost more money and there is a point when they need to say 'Enough is enough'.
Each mod I do is removing the comfort factor of the car and turning into performance.
Willf/Pie My mounts aren't munched.
Infact, thanks to the PU sealent, they are probably better off than they ever have been.
Granted, having solid engine mounts would also eliminate the problem, but they cost
Hardcore drivers only need apply then!!
Originally Posted by Pie_n_Chips,Apr 15 2009, 08:46 AM
Under bonnet bling, nothing more.
Your noticing a HUGE improvement because your mounts are shagged, allowing the huge amount of play your experiencing.
I'd consede throttle response may have improved due to you engine no longer being able to swing around as much in the bay, but come on
2-3" movement
Originally Posted by JD_S2k,Apr 15 2009, 10:33 AM
I'm going to fit one just because I'm planning on using the car properly this year
I fancy the NRG one.
Under bonnet bling nah, i have noticed a difference for sure but not as much as Ron has. The engine is inline anyways.
I havent really noticed much more vibration inside.
If your getting upto 3" of lateral movement prior to fitting your damper somethings munched fella PERIOD - I dont care how much PVA glue you used rebuilding the thing, it's goosed, get a new one. In fact I'd replace the N/S one as well as that probably took a beating when you O/S one gave up the ghost!! Hell the rear two too.
But your alright cuz you brought a torque damper init
