Engine fault light
Originally Posted by Dembo,Jan 14 2006, 07:18 PM
There was a bit of a petrol smell when I was stopped, if that's significant.
If you'd run it backwards for any length of time it's possible to set fire to the intake system but unlikely to happen unless you were running it downhill a long way or, as I've seen, when a contractor was putting in a new dyno at work they got their wires crossed so the dyno tried to run backwards.
More you describe it the more it sound's like that.
There'll be some kind of feature on the crank that will be picked up by a sensor to instruct the ECU where the crank position is. There'll be another on each cam-shaft that has some level of variable timing (the ones I use are on intake only since it's intake only variable timing) to let the engine know where they are. If the ECU gets those signals in the wrong order (such as it's running backwards) it'll go into back-up mode.
