Engine knocking
Old Apr 19, 2016 | 03:40 AM
sleepysnake's Avatar
Mine makes a similar noise when revs drop below 900 rpm when the engine is cold on a cold (sub 5c) day.
Cannot be heard once warmed up. My engine has 107k but had a new oil pump at 99k.
Old Apr 19, 2016 | 07:06 AM
gbduo's Avatar
Have you taken the rocker cover off? Just to check there is nothing loose in there?
I guess you could also try a thicker oil which if that solves it would indicate bearing wear.
Old Apr 19, 2016 | 09:08 AM
flanders's Avatar
Have you checked the valve clearances?
Nice to see another ITB setup btw
Old Apr 19, 2016 | 09:13 AM
unclefester's Avatar
Have you also checked the tensioner pulley / bearings?
Old Apr 19, 2016 | 09:59 AM
rnibleck's Avatar
Going to whip the cover off this weekend and see if I can see owt, I do have some cams to throw in it so will rebuild the head when I do that. If it still knocks then poo...
I may order an oil pump
Flanders - the itb's are fantastic!
Old Apr 19, 2016 | 11:42 AM
DaveUK's Avatar
I can't remember exactly how mine sounded, but it's worth checking these.
Old Apr 21, 2016 | 05:09 AM
chrome233's Avatar
The Engine in my old S2000 used to make the exact same noise, A lot of people over in the US also used to and still do have the same noise and there are many threads on it.
I found the noise changed if you pulled out the coils one by one, suggesting that it is a piston/bottom end related noise
No one actually knows for sure what it is but the majority think it is Piston Slap as it is only there at Idle. I worried about it for months with my last car and eventually just decided that its not worth worrying anymore. Lots of people said that had they have had the noise for years, but i have never seen any threads say that the noise resulted in any engine failure.
Also out of interest what year is your engine?
Ill try to find some of the threads.
Old Apr 21, 2016 | 05:30 AM
chrome233's Avatar
Have a read of this: https://www.s2ki.com/s2000/topic/110...age__hl__knock
Old Apr 22, 2016 | 01:49 AM
rnibleck's Avatar
Cheers fella, I will have a read of that thread tonight.
Car's a 99 but had a spoon bottom end put in in 2004.
I think it could be in head as it was first apparent after we re fitted the head a couple of years ago, I had completely forgotten about it till my mate told me last night.
Spec_Ops2087
Jun 21, 2013 08:23 PM
K3Nguru
Apr 13, 2012 09:58 AM
savesday04
Apr 13, 2009 12:43 PM
jguerdat
Sep 17, 2008 05:11 AM
VashRacing
Aug 15, 2008 01:41 PM
