Engine light on dash has lit up
Old Jul 9, 2006 | 06:12 AM
s2000 gib's Avatar
Default Engine light on dash has lit up
Help pls. Just been out for a drive, decided to wash the car and once finished and started up, the eingine light on the dash came on. Switched the car off for 20 mins and then checked the oil in case but was 2 notches from the top. Car was driving fine, only thing I can think of is the weather was about 30 degrees and the top of the airbox was off, could that affect in any way?
Should I reset the ECU and then see if the light comes on again? If so, any ideas how to go about it?
Thanks
Andrew
Old Jul 9, 2006 | 06:25 AM
MB's Avatar
MB
Member
Hi Andrew
It could be one of a thousand things. You need to pull the code from the ECU before you reset. All the answers to your questions are in the FAQ in "Under the hood" section
MB
Old Jul 9, 2006 | 06:28 AM
s2000 gib's Avatar
Hey Mark,
Thanks for that. I'll go have a quick read now then.
Andrew
Old Jul 9, 2006 | 08:12 AM
s2000 gib's Avatar
Just gone down to the car to get the manual out, started it up and the light has disappeared!! Either way, going straight down the dealers tomorrow and see what they can pull up when they hook up to their 'system'. The light wasn'nt flashing, it was just constant, although in the 'under the hood' forum it said this could mean the service schedule is due?
Wish me luck folks lol.
Andrew
Old Jul 9, 2006 | 09:08 AM
mikey k's Avatar
Nope UK cars don't have the service indicator on them.
Sounds to me like water got where it shouldn't anf then dried out.
Get the code pulled for peace of mind.
Old Jul 9, 2006 | 05:24 PM
s2000 gib's Avatar
I thought that too Mikey, only problem is, if the indicator light has gon off......will they still be able to pull the code from the car?
Let you know what happens tomorrow.
Gnite folks
Old Jul 10, 2006 | 12:02 AM
mikey k's Avatar
IIRC they can still pull the code if the light has gone off so long as you don't reset the ECU!
Old Jul 10, 2006 | 03:32 AM
Rawhide's Avatar
Correct. If your not near a dealer buy an ECU reader of ebay and do it yourself.
Old Jul 10, 2006 | 05:19 AM
AquilaEagle's Avatar
Administrator
Had you recently filled up with fuel?
S2K-Neil
Nov 6, 2007 04:49 AM
JayStyles662
Dec 28, 2006 08:38 AM
TheLoons12
Aug 5, 2006 10:27 PM
Whitelightning
Dec 3, 2005 05:36 PM
blackfx35
Aug 31, 2005 04:57 PM
