Engine Numbers
Old Sep 6, 2013 | 07:52 AM
PTR300's Avatar
Default Engine Numbers
Tried searching the forums for info on the location of the engine number to no avail.
I know the plate on the right side of the slam panel has it on but is there a number on the engine block somewhere?
I am trying to find out if the car has had a replacement motor...interestingly the cars log book does not record a number.
Old Sep 6, 2013 | 09:53 AM
Mad Mart's Avatar
Yep, left hand side of engine (right as you look at it from the front) just behind and below the aux. belt tensioner. You'll see a flat surface. Maybe dificult to see in situ though.
Old Sep 7, 2013 | 03:52 AM
PTR300's Avatar
Thanks for that, MM, couldn't see it at first but it was covered in cr ap...
added a couple pics so others can see too.
NOT very easy to see but mine matches with chassis plate on slam panel, so original engine
Old Sep 7, 2013 | 08:58 AM
Nick Graves's Avatar
It's a bugger to read the final digit; I wet it with a Q-Tip in some forceps, to bring out the digits.
I also found there is a part no. barcode sticker by the crank pulley; a smartphome & a powerful torch will allow you to photograph it in order to read it.
Old Sep 7, 2013 | 09:35 AM
PTR300's Avatar
definitely a looooong way back !
managed to clean the panel off with ferrosol and a cloth on a screwdriver...last digit just visible...ish ! anyway it was either a 6 or 8 and I went for six and when I checked the plate it was the same....can't understand why the V5c doesn't record it......
Won't be disturbing anyone in the DVLA anytime soon though
Old Sep 8, 2013 | 08:14 AM
That was exactly my problem!
By photographing the bar code sticker I was eventually able to confirm a 6 in the end.
Old Sep 8, 2013 | 09:30 AM
PTR300's Avatar
Do you have a plate on the bonnet slam panel, to the right?
I have the engine number on there but wanted to confirm the ACTUAL engine number on the block hence the thread...
Old Sep 8, 2013 | 11:51 AM
K3Nguru's Avatar
You need mirror (and flashlight). That's how I managed to mine.
Telsheds
Dec 3, 2012 10:59 PM
unclejemima
Jan 15, 2009 05:39 AM
s2k_redhead
Jan 5, 2009 08:58 PM
Andre
Jun 10, 2005 05:25 AM
jwkim
Dec 5, 2003 11:49 AM
