Engine rough when cold
Old Apr 19, 2005 | 12:03 PM
Bassoctopus's Avatar
Cheers Brian, I'll have a look.
FYI Plugs were changed at 54k, 2 years ago. If I end up changing the plugs should I stick with the Honda OEM or can you recommend something better for a standard unmodified car.
Old Apr 19, 2005 | 12:58 PM
simonprelude's Avatar
FWIW my engine started like this, as Brian says carefully check the symptons and if like mine get to the stealer ASAP, don't want to start scaring people, but better for a check than a snapped valve righting your engine off !!
Old Apr 20, 2005 | 12:48 AM
Colin Andrews's Avatar
Rough is bad However, other easy things to check - crudded up injectors (poor atomisation of the fuel - poor combustion when cold)? Redex or some other injector cleaner.
Bad earth from engine - high impedence to sparks? Check main engine earth point, if it's is manky clean it and cover with a dod of grease after re-fit.
On another note - my '01 twice misfired on start up when really cold - but I got a check engine light.
HTH
Old Apr 20, 2005 | 02:45 AM
Turtle's Avatar
See what they're like first. You can get a small improvement in low rev behaviour with the right temperature iridum plugs (about
Old Apr 20, 2005 | 09:59 AM
Mans Best's Avatar
Battery nearing the end of its life? If you hadn't driven the car for a week and it had drained a bit, that would explain why it was OK later.
I always look for the simplest things first
Old Apr 20, 2005 | 10:56 AM
Interesting point Man's Best, because the alarm went off when I started the car. I unlocked it, drove it out the garage, put my other car back on the drive and when I went to start the S2k the alarm went off. Took a while to get it turned off too.
Could the battery make the car run badly?
Old Apr 20, 2005 | 04:59 PM
Mans Best's Avatar
I believe it could, yes. A depressed voltage from the battery coupled with the effort of starting the engine that would depress it even more, would result in a reduced spark and less efficient combustion unless anyone thinks differently. Can't see myself how the engine management can compensate but maybe it's that clever. One cell of my battery died and I couldn't even get the car started after it had done a couple of miles, so that indicates nothing works below around 10.5 volts.
How old is the battery?
Old Apr 20, 2005 | 10:38 PM
I don't kow the age of the battery. The car is 5 yrs old and doesn't have Honda branded battery so I assume it's already been changed once.
jabbarahm
Dec 7, 2010 01:58 AM
mk84
Apr 21, 2008 10:10 AM
alex.stanley
Jul 12, 2005 01:14 PM
DJHohum
Feb 20, 2001 11:32 AM
