Error Codes
Old Apr 27, 2006 | 08:43 AM
J33LUS's Avatar
Default Error Codes
I posted a few weeks back as MY04 wont rev over 3,000RPM.
I bought a ODB Reader and it came up with the following 5 error codes :
P0122 Throttle Position (TP) Sensor Circuit Low Input
P1298 Electric Load Detector (ELD) Circuit High Voltage
P1367 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) No Signal
P0412 ?
P1412 ?
The bottom two are not listed in the FAQ, anyone know what these are?
What is my next point of call, do I contact the stealer, or locate someone else to put right?
Thanks
J33LUS
Old Apr 27, 2006 | 08:50 AM
AquilaEagle's Avatar
Administrator
if they begin with P0 they are generic OBD codes, there should be a book with your reader which lists them.
P0412 is Secondary Air Injection System Valve A Malfunction
If they begin with P1 they are manufacturer specific codes, and should be listed in the FAQ. I think 1412 will be the same as 0412
I have no clue what next, all sounds horrible to me!
Old Apr 27, 2006 | 09:18 AM
mzm70's Avatar
There is a copy of the Honda 2000-2003 Service manual in PDF format flying around.
Seems to have some decent troubleshooting guides.
PM me
Old Apr 27, 2006 | 09:27 AM
J33LUS's Avatar
Me too, found the book I got with the reader:
P0122 TPS/Pedal Position Sensor A Circuit Low Input
P0412 Secondary Air Infection System Valve A Malfunction
P1412
How have people got their error codes fixed, via the Stealer?
Old Apr 27, 2006 | 09:41 AM
LTB's Avatar
LTB
May be worth PMing Turtle, I'm sure he could shed some light on the situation.
Old Apr 27, 2006 | 10:07 AM
MB's Avatar
MB
Member
First one is the throttle sensor which lives on the throttle body. That could be related to your problem, as could the crank sensor.
Do you have a CEL still lit up on the dash?
If you have a code reader these can be reset / cleared. Any background to how the faults came up would help too.
MB
Old Apr 27, 2006 | 10:08 AM
Administrator
Yes usually the dealer fixes Error codes.
If you want an electronic Service Manual on CD rather than pdf there are also some flying around
Old Apr 27, 2006 | 10:57 AM
s2konroids's Avatar
Sorry to hear this mate, maybe if you reset it may rev above 3000 now that you have indentified codes, but i personally would not.
Old Apr 27, 2006 | 11:06 AM
J33LUS's Avatar
MB
I CEL light is still on, I havent cleared this as I thought the problem will still be there.
If I do delete the codes, do you think it would rev over 3,000rpm?
Dont know how the faults came up, car has been garaged since it was imported in uk a few months ago.
Old Apr 27, 2006 | 11:15 AM
MB's Avatar
MB
Member
Im not advising either way, but I would if it was mine, as long as I knew the codes.
The 2 that look odd are the 2nd and 3rd ones, and these 2 are the likely ones that wont let the car rev IMO.
P1298 Electrical Load Detector Circuit High Input.
P1367 TDC Sensor No. 2 Signal.
If there is a genuine problem they will come back pretty quickly. If they do come back I would get it looked at.
Im sure others will disagree but thats my spin on it.
MB
