Error Codes
I posted a few weeks back as MY04 wont rev over 3,000RPM.
I bought a ODB Reader and it came up with the following 5 error codes
P0122 Throttle Position (TP) Sensor Circuit Low Input
P1298 Electric Load Detector (ELD) Circuit High Voltage
P1367 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) No Signal
P0412 ?
P1412 ?
The bottom two are not listed in the FAQ, anyone know what these are?
What is my next point of call, do I contact the stealer, or locate someone else to put right?
Thanks
J33LUS
: P0122 Throttle Position (TP) Sensor Circuit Low Input
P0412 ?
P1412 ?
Thanks
J33LUS
if they begin with P0 they are generic OBD codes, there should be a book with your reader which lists them.
P0412 is Secondary Air Injection System Valve A Malfunction
If they begin with P1 they are manufacturer specific codes, and should be listed in the FAQ. I think 1412 will be the same as 0412
I have no clue what next, all sounds horrible to me!
P0122 TPS/Pedal Position Sensor A Circuit Low Input
P0412 Secondary Air Infection System Valve A Malfunction
P1412
How have people got their error codes fixed, via the Stealer?
First one is the throttle sensor which lives on the throttle body. That could be related to your problem, as could the crank sensor.
Do you have a CEL still lit up on the dash?
If you have a code reader these can be reset / cleared. Any background to how the faults came up would help too.
MB
MB
MB
MB
If I do delete the codes, do you think it would rev over 3,000rpm?
Dont know how the faults came up, car has been garaged since it was imported in uk a few months ago.
Im not advising either way, but I would if it was mine, as long as I knew the codes.
The 2 that look odd are the 2nd and 3rd ones, and these 2 are the likely ones that wont let the car rev IMO.
P1298 Electrical Load Detector Circuit High Input.
P1367 TDC Sensor No. 2 Signal.
If there is a genuine problem they will come back pretty quickly. If they do come back I would get it looked at.
Im sure others will disagree but thats my spin on it.
MB
MB
