Fitting New Pads
Fitting New Pads
I've been advised a couple times now that my pads are getting low and I should replace them and also that the discs are lipped and should get them changed too.
To try describe my discs I'd say they have a lip on the outer edge on the front and back face of the disc. The lip is 1-2mm deep at best guess but other than that the rest of the disc looks in good condition.
I figure that when I put new pads on, this lip will cut into the pad and the issue will persist.
Is there any point in changing the discs or could this lip be simply removed without refacing the entire disc? Also, does it matter or should I just bung on a set of new pads and forget about it?
Member
The lip is actually the original part of the disc - the pads dont contact the outer edge, so as the disc wears it leaves that lip on the outer edges.
New pads wont touch the lip either, they will continue to wear the disc in the same place.
Sounds like you need new pads and discs.
As for new discs, I assume standard steel discs are all the same thus no need to go for Honda OEM, just go for the Brakes Int. ones as they are a good price.
I wonder if it's worth adding something about brakes (disks and pads) to the FAQ? There seem to be a lot of questions about them at the mo and several different options (BrakesInternational, BrakeParts, etc).?
Another problem, the lip gets in the way when trying to rotate the caliper off the disc to remove the pads. Is there an easy way to retract the cylinder while the caliper is still over the disc?
Originally Posted by Dembo,Sep 12 2007, 12:56 PM
Have you undone both bolts?
lower
09-21-2009 12:11 PM
