fluid question
Old Apr 6, 2008 | 06:54 AM
paul-w's Avatar
Default fluid question
What clutch fluid is recommended for the s (would any dot4 be ok) and how much do i need , mine is looking a bit black so want to replace it.
Im also doing a oil and filter change , oil will probably be mobil1 5-40 fully syn and finally am i best to use a genuine honda oil filter, thanks
Old Apr 6, 2008 | 07:04 AM
mikdys's Avatar
Any DOT 4 should do (250ml would be enough for the clutch).
The oil filter you need is the one in the top in the picture (and make sure you torque it down with a special tool - suppoesedly available from Honda - do a search for other threads on this). Mobil 1 will be fine (get 6 litres though - the sump takes a bit more than it says in the book if its been fully drained).
Old Apr 6, 2008 | 07:35 AM
paul-w's Avatar
Thanks
Curated Content Editor
Jul 13, 2017 07:20 PM
JohnnyJuan
Mar 4, 2013 04:14 AM
DNDN_S2000
Sep 17, 2011 08:44 AM
Riceboi
Feb 25, 2006 03:25 AM
kush only
May 14, 2003 10:51 AM
