Front bumper retainer plate
Old 11-08-2022, 09:41 AM
Nottm_S2's Avatar
Default Under Bonnet detailing - a blog
This is annoying me on both cars
this is the largely stock car, it was a daily for a long time but is now a strictly sun's out garage queen
The little Phillips bolts are annoying and complex, they have a sleeve to locate the plate, so a stepped shank but seize in place and strip when you try to remove them as you can see
will drill/Dremel these out later
The plate itself sits in water for a car living outside as the SC one does
Start point on NA
Not really good enough to make look perfect easily so I bought a new one from Tegiwa for about £25
well 2 actually
Now I wanna rust proof them so thinking powder coat.. or I could spray them some more - I know the honda paint is pants
I ordered stainless fasteners, M6 x 15 and will grease the threads and tidy up underneath when it's off
will update once it's all done
rad stays next, I plan to progress back, tidying it all
Old 11-08-2022, 10:07 AM
CHIPPO's Avatar
M6 stainless bolts and washers, ( big washers) fit fine as I recall, that’s what’s on mine
Nottm_S2 (11-08-2022)
Old 11-08-2022, 11:44 PM
U9aXy6Dn's Avatar
The irony - I've just bought a UK plate holder to re-install on my aftermarket bumper because it just looks so much more 'finished'.
Old 11-09-2022, 12:25 AM
Irish TuneR's Avatar
I used the same as Chippo but with fancy washers, also they're not Philips head bolts they're JIS. I bought a set of JIS screwdrivers this year and its amazing the fit difference between that and a Philips head on JIS bolts.
Old 11-11-2022, 04:36 AM
Nottm_S2's Avatar
Took them to be powder coated this week
they stripped them.
Rusty under the paint
I guess this would cause poor adhesion, poor coverage and the subsequent rampant rust I have experienced on these in both cars
anyway, out with the old on the SC as it heads to MOT
Old 11-13-2022, 08:19 AM
Nottm_S2's Avatar
The other car was harder as the OEM Phillips bolts were still on it
tried cutting slots, no joy, the metal just gave way
Stud extractor worked but one snapped, I got the rest out with a bit of ****ery
Then I realised I'd put the other one in upside down.. doh
Both on now with liberal ACF50
Old 11-23-2022, 01:16 AM
See below, Jap car=Jap fittings.
Nottm_S2 (12-09-2022)
Old 11-23-2022, 05:12 AM
Nottm_S2's Avatar
Ah . Get it now
https://chapmanmfg.com/blogs/news/ph...the-difference
Sledgehammer beats subtle for me
Every day is a school day - thanks
Irish TuneR (11-24-2022)
Old 11-27-2022, 03:46 AM
martin j's Avatar
Had a look and discovered the strange Philips bits I have aren’t Philips but JIS, result, box now marked accordingly.
Old 11-27-2022, 06:51 AM
Nottm_S2's Avatar
2 students then
So onwards with tidying under the hood I removed the cam cover and started to strip it
I used frost strip gel as I heard a lot of complaints about paint stripper from a DIY shop and it was very effective, just lots of nooks and crannies
before
This is OEM 2001 vintage
During (the odd crannie yet to do but 95%).. it's drying in the kitchen as it won't in the garage this time of year I guess
Next is home brew electro plating (of bolts) and paintshop.. I don't think it will fit in my oven for curing alas
The following 2 users liked this post by Nottm_S2:
martin j (11-27-2022), WallaceS2K (11-28-2022)
Quick Reply: Front bumper retainer plate
