Hardtop Strikers
Old Sep 15, 2011 | 12:32 AM
Floppy's Avatar
Default Hardtop Strikers
I was just wondering whether someone can confirm if this is the right part before I order? My striker plates on the windscreen frame are pretty worn and as a result the hardtop I have bought recently rattles even after adjustment.
Please can someone confirm whether part number 11 in the link below is the correct part? I'm just after the striker plate on the windscreen frame that will be suitable for both a hard top and the soft top.
CFL Honda - Hard Top Diagram
TIA
Old Sep 15, 2011 | 12:47 AM
xoz's Avatar
xoz
no that's for the rear latches, it's like the top half of the actual latch..
CFL NO 4 but for soft top.... http://www.cflhonda.com/partlocator/...layCatalogid=0
HTG has this, which is what you want ....HT strikers.
http://www.hardtopguy.com/store/home.php?cat=92
Old Sep 15, 2011 | 08:24 AM
ogg2000's Avatar
CFL Honda provide great service and prices in my experience but their website is "challenging".
The best thing I found to do was use HondaPartsNow website to find the part numbers and then search using these numbers on CFL Honda's website.
Another problem with CFL is that your order doesn't show the part number and the descriptions can sometimes be misleading as well as vague. When I ordered I specifically requested they checked one item - they did and all was fine.
D.
PS If anyone wants the hardtop fitting kit numbers - I can advise
Old Sep 15, 2011 | 10:11 PM
S2000_FUN's Avatar
I think the correct Honda part number is 86270-S2A-902
Chris
Old Sep 16, 2011 | 01:16 AM
carlip8's Avatar
Chris
Spot on.
Have you tried your local dealer Floppy, I asked Rowes Honda, Plymouth, £36 for HT strikers, 2 day turnaround for them to arrive if not in stock...
Old Feb 21, 2012 | 06:04 AM
Floppy's Avatar
Thread resurrection!
I never got around to buying new strikers and since removing the hard top after the winter I now get loads of wind noise from the soft top as well! When I pull the handle at the front down towards the mirror the wind noise disappears. Does that mean I just need new strikers or do I need the shims as well? My strikers are seriously worn now to the point where there feels like there is almost no grip when closing the hard top or soft top latches!
Old Feb 21, 2012 | 07:23 AM
carlip8's Avatar
Have you tried swapping the strikers around, driver-side to passenger-side and vice versa, could be a temp fix until you sort some new strikers out...
sohailnisar
Jan 23, 2016 11:40 AM
pontypridd
Aug 22, 2015 03:57 AM
pkane32
Oct 27, 2012 02:21 PM
ssms2k
Nov 14, 2007 07:15 PM
stevedrakeuk
Aug 19, 2002 04:43 AM
