Has anyone successfully fitted a sub and amp under the passengercseat ?
Old 10-27-2013, 11:42 AM
GreenmanS2000's Avatar
Default Has anyone successfully fitted a sub and amp under the passengercseat ?
I've read all the search results but can't find an answer to whether the alpine sub and amp will fit.
I have all other Alpine kit so would prefer to keep with it but the focal sub looks a reasonable alternative
Old 10-27-2013, 11:45 AM
jimmyb1978's Avatar
Well I thought that the rip speed sub with built in amp was a bit if a squeeze and it didn't perform that well so doubt if 2 separate items would fit?
Old 10-27-2013, 12:15 PM
SuperHamz's Avatar
Can't it fit to the left of where the spare wheel is in the boot?
Old 10-27-2013, 01:20 PM
jimmyb1978's Avatar
Seperately my amp is located inside the spare wheel and I have a proper box in the boot
Old 10-28-2013, 02:31 AM
TangoVTEC's Avatar
^ how does the boot option sound? Is it that noticeable?
Old 10-28-2013, 02:45 AM
UK Moderator
lovegroova's Avatar
I have something similar (see my signature for photos) and I can confirm it sounds very good.
You do need to be a bit careful with the setup as if you set your crossover at too high a frequency (the most common mistake people make) the sub starts to produce too many frequencies which can be determined as "directional" so it sounds like the notes are coming from the boot, which you don't want.
i.e. you want to hear the low frequency stuff, but not be able to tell where it is coming from.
Old 10-28-2013, 04:43 AM
flybikeslee's Avatar
stelongy fitted a ripspeed one under the seat. sounded alright for very little money
Old 10-30-2013, 03:29 AM
J1mmys's Avatar
Looks a tidy job that mate, well done!!
Old 10-30-2013, 03:46 AM
jimmyb1978's Avatar
Wish I could take the credit but it's from www . Darksidesubs
Old 10-30-2013, 01:41 PM
I like those dark side units but they seem I bit expensive by the time they arrive in the UK.
Maybe I need to up my budget
Quick Reply: Has anyone successfully fitted a sub and amp under the passengercseat ?
