Help with diagnostic codes
Old Jan 29, 2010 | 09:42 AM
gerk's Avatar
Default Help with diagnostic codes
Hi,
Ive been having a problem with my abs light coming on when i go over about 130k and the abs cutting in when slowing from about 5km to 0. Though the abs only cuts in if the abs light isnt on.
a garage plugged in the diagnostics and 2 codes came up, 18-1 and 24-1.
does anyone know what these codes refer to?
im thinking its the abs sensor but i wasnt expecting 2 codes only one.
appreciate your help,
Ger
Old Jan 29, 2010 | 09:48 AM
leftfootbraking's Avatar
https://www.s2ki.com/forums/index.php?showtopic=301506
half way down is a full list of codes
Old Jan 29, 2010 | 09:52 AM
gerk's Avatar
ya i cant find it on that list!
Old Jan 29, 2010 | 12:06 PM
s2konroids's Avatar
24 - pulser RL
18 - wheel senor (electrical noise/intermittent interuption) RL
I have some of these i was trying to read ABS codes for a program which i aint got round to doing
Note i cant gaurantee these are correct, you garage must have a simple reader as most have an LCD screen and can output the text too.
Old Jan 29, 2010 | 12:11 PM
gerk's Avatar
Originally Posted by Irvatron,Jan 29 2010, 01:06 PM
24 - pulser RL
ya, thats what came up on the reader. will replacing the sensor sort out both codes??
Old Jan 29, 2010 | 12:15 PM
s2konroids's Avatar
Actually its
18 - left rear wheel sensor
24 - left rear pulser
I think replacing the sensor will be get rid of both codes, though dont quote me on this!!
Old Jan 29, 2010 | 12:17 PM
gerk's Avatar
Ha ha, thanks for the help.
this might seem like a stupid question because im not the most technically minded but what is the pulser?
im guessing its got something to do with the wire between the sensor and what its connected to!
Old Jan 29, 2010 | 12:26 PM
s2konroids's Avatar
Simplyput: Basically a gear (circle) with teeth on it, but if the sensor is broke it wont get the pulse/speed back it wants or expects.
The gear could be damaged but i doubt it.
Siby
Apr 15, 2012 04:11 PM
Spec_Ops2087
Nov 22, 2010 11:10 AM
C-IS
May 5, 2005 10:06 PM
intake
Aug 21, 2004 02:07 PM
intake
Aug 17, 2004 10:15 PM
