HELP NEEDED
Old Aug 30, 2006 | 04:43 AM
littleandy's Avatar
Default HELP NEEDED
My S has failed it's MOT because it has got a sports cat on. They say the emissions are double what they should be.
Anyone got any idea what i could do?
Carn't believe this, this is why i didn't put a straight pipe on so i didn't have the hassel on it's MOT.
Old Aug 30, 2006 | 04:51 AM
paullec's Avatar
afraid yourll have to take it off and replace it with OE or find a friendly garage maybe they didnt let the engine warm up properly before doing the emission test ? i know my garage left it running for ages when i took here in for the MOT last week.
Old Aug 30, 2006 | 04:54 AM
Bassoctopus's Avatar
Straight pipe would have caused the same problem, you need to keep your OEM CAT for MOTs
Old Aug 30, 2006 | 05:07 AM
hyb's Avatar
hyb
Whats the point of a sports cat in that case
Old Aug 30, 2006 | 05:12 AM
littleandy's Avatar
The OEM Cat was f**ked thats why I changed it. When we took it off it was ratterling around inside.
Old Aug 30, 2006 | 02:17 PM
S2K-Neil's Avatar
sounds a bit like my cat, looking at getting a replacement cat at the mo
Old Aug 30, 2006 | 11:28 PM
simonprelude's Avatar
Breakers are your friend
Old Aug 30, 2006 | 11:45 PM
eSeM's Avatar
Originally Posted by littleandy,Aug 30 2006, 12:43 PM
Can't believe this, this is why i didn't put a straight pipe on so i didn't have the hassel on it's MOT.
What is the difference between a sports cat. and a straight pipe?
Did anyone tell you the car would pass the MOT with it?
Old Aug 31, 2006 | 03:57 AM
MB's Avatar
MB
Member
The term sports cat is generally described as one which gives a high flow, but still contains catalyst and is intended to pass an MOT.
Im not aware anyone makes one for the S, and not really sure it would be worth it for the ease of removing a decat pipe.
A de-cat is a straight pipe, sometimes with a resonator inside. It does nothing for your emissions.
Which one did you buy??
MB
rossco
Mar 11, 2016 12:53 PM
cat5cable
Oct 9, 2013 01:24 PM
S2Kmonkee
15
May 4, 2010 10:11 AM
Shipley
Dec 3, 2007 12:34 AM
sabry
Jun 7, 2006 12:44 PM
