Help please - replacement engine
Old Apr 4, 2007 | 05:08 AM
Jel's Avatar
Jel
Default Help please - replacement engine
Thursday night my car sounded like Satan gargling spanners so I had it towed home then to Honda next morning.
They have only just got round to looknig at it and have said they replaced the tensioner, it sounds better but still awful. They say there is probably (sounds to me like they haven't done a proper investigation) big end damage - bearings/crank shaft etc and do not recommend replacing parts due to problems with metal contamination. Upshot is they want to replace the lump entirely and are getting back to me with prices.
When I heard the noise I was prepared for thousands not hundreds but clearly do not want to pay out unnecessarily. So, do I:
1. take a chance on flushing engine and replacing parts?
2. get Honda to roger me silly for a new engine?
3. get a used one (04+ recommended?) and them to fit it?
4. tow it to the country and burn it?
I know there have been a few 'deaths' here recently, any advice please?
EDIT: 3 weeks ago i got a CEL and took it straight in. They said it was a misfire in cylinder 2 and swapped plugs and coils and it was ok. Is this related? Was there damage that could have been prevented - do I have a 'case'?
Old Apr 4, 2007 | 05:14 AM
W9NGJ's Avatar
if uve got protected NCB
burn it lol
Old Apr 4, 2007 | 05:39 AM
lower's Avatar
I suffered an engine failure with my MY00. Its not nice.
Luckily mine was under warranty. A new complete engine fitted by Honda is
Old Apr 4, 2007 | 06:31 AM
Nottm_S2's Avatar
a used engine fitted will set you back c 2-2.5k
and it's the only way to go. legally
how many miles??
Old Apr 4, 2007 | 06:46 AM
Jel's Avatar
Jel
68003, may have something to do with me shifting down to 4th at 5 redline though.
Old Apr 4, 2007 | 06:51 AM
Rapscallion's Avatar
been there done that, no4 conrod at 68,500
phone the breakers in the for sale section and see what they have.
the ones at the top are usually best. be interesting to see what they quote.
i got a 2002 engine with 23000 for 2000 +vat and got it fitted at a garage for
Old Apr 4, 2007 | 07:00 AM
lower's Avatar
if you over revved it, then you will most likely have also damaged the valve spring retainers.
If you're going to rebuild the bottom end, bear this in mind as you don't want a subsequent engine blow up due to a failed valve spring retainer and the subsequent dropped valve.
Old Apr 4, 2007 | 08:09 AM
Bada Bing!'s Avatar
Banned
When did your Honda warranty expire? No chance you can continue it over, leave the car off the road for a month or two then claim on it?
Old Apr 4, 2007 | 08:20 AM
Jel's Avatar
Jel
I personnally have never had a warranty on this car. I thought any extended ones had to be continuous?
Old Apr 4, 2007 | 08:29 AM
five_belliez's Avatar
i think the breakers will be the only way forward if they really think it will involve a new lump or major surgery. sorry.
