Help! T1-R testpipe group buy thread
The form AE has put up doesn't help me and I've gone thru tons and not found it.
There was a (not too long ago) T1-R testpipe group buy. It had pics on how the flow sensor should sit, and also other things to watch for, CEL etc.
Anyone got it bookmarked? Gonna go get mine fitted as soon as I have the info.
Saxyboy????!!!! I know u were on the thread!
Didn't book mark it and just checked through my PMs and I have not links to it there.
It's really easy to install though. Remove old pipe - put new pipe in place. Use drilled anti-foulers x2 and screw them into where the sensor goes and then screw the sensor into the anti-foulers. If you take the sky to be zero degrees most people find the sensor sits at approximately a 140 degree angle and in my case the wire for the sensor is probably the lowest part of the car I just exercise caution over rough ground or speed bumps. With the two antifoulers I've never had a CEL or a problem.
If you decide to manually look for the thread I'd say the last post on it would be around september time
It's on but the o2 sensor points down. Couldnt find any other way to do it.
I've already got a chunk out the exhaust where the pipes split so i can't see it lasting long LOL
Where do i get an O2 simulator plug from, and how much are they?
