How the hell do you remove the stock Shift knob ?
Old Sep 14, 2002 | 11:00 AM
ChrisB's Avatar
Default How the hell do you remove the stock Shift knob ?
I have a titanium spun voodoo shift knob and wish to isntall it asap. Getting the stock shift knob removed is the problem. According to the instructions you should "Simply release the lock nut at the base of the stock shift knob. Unscrew (counter clockwise) the stock shift knob. Then remove the lock nut. Next screw on the new S2000 Voodoo Shift Knob".
I see a "nut" of sorts at the abse of the knob, but trying to loosen it seems impossible. I am scared of damaging the actual gear shaft by twisting too hard.
Help ?
Chris
Old Sep 14, 2002 | 11:17 AM
silverstreakn's Avatar
Chris, your instructions are correct. I had to remove the shift knob to install Rick's console cover and my lock nut was tight as well. To release the lock nut, you need to turn it clockwise.
Don't worry, it'll break loose!
Old Sep 14, 2002 | 02:33 PM
stockport_lad's Avatar
Chris, its the same old problem, sticky nuts. See you at the Romper I know there will be someone there that can release that tention for you
RXM9600
Jun 22, 2013 08:11 PM
HaveANiceDaisy
Sep 27, 2012 06:31 PM
naruto
Nov 16, 2006 12:36 AM
McS2K
Aug 25, 2006 10:05 AM
AustinS2k2003
May 10, 2004 10:04 AM
