how straight forward
Old 11-13-2011, 02:04 PM
Venna's Avatar
Default how straight forward
im wanting to lower my car but is it as straight forward as just fitting coilovers or will i have to perchase other bits and bobs as well for the car to drive right?
cheers
James
Old 11-13-2011, 02:13 PM
UK Moderator
lovegroova's Avatar
Yes, it's as simple as that. If you want to lower more than 3cm or so, you will need other bits. Have a search for more info, There's tons out there.
Old 11-14-2011, 11:47 AM
Administrator
AquilaEagle's Avatar
You might want to purchase drive shaft spacers too.
Old 11-15-2011, 07:01 AM
loftust's Avatar
You should check the adjustment/alignment bolts are free before even thinking about spending money on modifications. To not do so would be foolish, potentially dangerous and will cause tyre wear issues.
Once you gave ascertained the state of these bolts (front toe/camber/caster and rear toe/camber) fitting the mods and getting the geo sorted is simple.
There are numerous threads detailing supporting info for the above
Old 11-15-2011, 02:08 PM
Venna's Avatar
[quote]You might want to purchase drive shaft spacers too. [quote]
why is this?
thanks for the info guys
james
Old 11-15-2011, 02:14 PM
Ultra_Nexus's Avatar
Do a search
Seriously, the truth is out there Agent Mulder.
Do a search for the following:
Steering rack spacers
Driveshaft spacers
bump steer
rear toe arms
After you have done that, come back to the thread and tell us what you have learned.
My guess is that you'll be better equipped to do the task in hand and know what you want.
Good hunting!
ChrisPackit
03-04-2019 09:12 AM
mike_s2000
05-26-2011 01:20 PM
s2000 gib
10-03-2010 08:26 AM
grantedS2k
06-11-2007 11:08 AM
DoubleOh2000
02-07-2007 09:11 AM
Quick Reply: how straight forward
