Interior lights problem
Old Mar 24, 2011 | 01:09 PM
s2konroids's Avatar
Default Interior lights problem
Hi,
Sometimes my interior lights wont come on, the actual switch/connection inside the light cluster is fine so its not that. I had removed the rubber dust caps present on the little door mechs/pistons (located on frame) a while back but seen nothing really to fix, IIRC i did lube them.
I do notice that if i wiggle the door mech the lights come on?
Any ideas?
Cheers
Old Mar 24, 2011 | 03:12 PM
robs_silver_s2k's Avatar
I have exactly the same issue but haven't investigated how to fix it yet!!
Old Mar 25, 2011 | 03:29 AM
GavB's Avatar
The door push switchs are crap. One of mine stoppped working at 2 years old. It and the other side are now both faulty again. Door switches are cheap and easy to change out. Confirm its the switch just by disconnecting the wire and manually grounding it, Light should come on.
Old Mar 25, 2011 | 03:39 AM
Bassoctopus's Avatar
Yep my drivers door switch is intermittent too. Just remove, clean and get some servisoil on it
Old Mar 25, 2011 | 04:49 AM
Dembo's Avatar
Mine have never worked. Maybe it's time I looked at it.
Old Mar 25, 2011 | 05:13 AM
veehexx's Avatar
if their the style i think they are (ie: generic halfords stuff), then they should be a few quid to replace.
same sort of cheap poxy switch they use for bonnet detection on alarm systems
remove said switch, a bit of sandpaper to clean up the contacts and some grease to prolong the issue.
Old Mar 25, 2011 | 07:09 AM
Nick Graves's Avatar
One tends to bend them getting in & out. Which is why they bind a bit.
Ryans S2K
Feb 19, 2016 12:49 PM
Devinb
Sep 27, 2010 11:10 AM
WLOCKARD
Sep 14, 2008 07:34 PM
Enthralled
Apr 8, 2007 12:47 AM
S2KNJ
Jul 14, 2004 09:01 AM
